When I put the transmission in D it will not engage unless I rev it to 2k rpms or so then it jumps in and drives fine. I do get the 1-2 hard shift though and have for awhile. I can drop it into L and it will shift into 1st then I can manually put it in drive and it drives fine.
The fluid level is fine and doesnt smell burned. Its the proper color as well.
I do not have 2.5k to rebuild it.
Can this be an issue with the valve body or is it toast?
