Weight distributing Hitch?
GreatExcape
I have a 2021 Max with the max tow package.
I also have a boat and trailer combination between 8 and 8.5k lbs.
I know a lot of guys run WDH's on campers to help with wind sway and what not, but do I really need one to tow the boat 45 minutes to the river and back on weekends? I understand that most vehicle manuals call for the WDH even when they are well overrated for the item being towed...
Running the WDH would require some modifications to the jack on my trailer and is also obviously far more expensive than a standard hitch. If I have to shell out the coin I will but if guys are towing boats like this regularly without one then I will invest in sumo springs, a rear sway bar, and a normal hitch...
Looking for opinions and real world experience.
Bonk
mke
The moment you bottom out the suspension setting the tounge down you’ll know. If not then, when you try to turn you’ll push.
JasonH
Houston, TX
My understanding is that boats tend to run light on the hitch. Your best bet is to visit a scale and find out how heavy the tongue load actually is. If you don't put enough weight on the tongue and use a WDH when it's called for, you may experience excessive sway while towing.
chuck s
One round trip will supply all the data you need. Motorboat trailers have different weight distribution and you may not need or want a WDH. Seems I answered this earlier today in another thread? But two guys with new boats is wonderful!
-- Chuck
Knut
Max Tow & Tongue weight is based on using a WDH.
r98exp1
