Drivers window needs re-initialized - Keyless Start
dkeyes
Southern Illinois
2015 Platinum, keyless start – Just replaced the regulator on the Drivers door. Had the battery disconnected for about 2 hours. Used the old motor. Window goes up and down manually AND using One Touch. But when going UP using One Touch, it stops about 2 inches from the top. I can get it the rest of the way up doing it manually.
I’ve tried:
With car running AND in just Accy mode;
Holding 3 seconds after going down and then again after going up.
Holding 3 seconds letting go, holding 3 seconds AGAIN after going down and then again after going up.
Nothing has worked.
xsacta
NY
Did you ever get it to work have the same issue 2016 ford expedition keyless
xsacta
NY
Did you ever get it to work have the same issue 2016 ford expedition keyless please help same issue
HazBeen
Great Lakes
Window Motor Initialization procedure from 2016 Expedition Workshop Manual is attached below...
Good luck!
  • Window Motor Initialization - General Procedures - 2016 Expedition Workshop Manual.pdf
xsacta
NY
thanks for that I try this how do you do it with a keyless car?
castawaypaul
