“Thunder” 1998 Expedition Build Thread
ExplorerTom
Colorado
Those lights are awesome! Would have had to of been one hell of a Black Friday sale though.......
Texpedition
Mesquite, Texas
I saw your thread on Lightninggarage.com and took note of your installation of the front bumper assembly. Where did you purchase those parts? I keep seeing those listed on ebay as bumper covers. You took your old bumper off, it appears, and installed the Lightning bumper right onto the front end. I have to replace my front bumper due to damage but won't waste the money if I can put a new Lightning bumper on in its place. Did you have to replace the brackets as well?
MISTERgadget
MISTERgadget
Miami
Skipped ahead! :angels2:
That's actually what I logged into to copy over today, the last few posts. What you're seeing on ebay is just the cover. They use the same steel bumper underneath as 99-02 expeditions and 99-03 F150s, without the top plastic cover or the airdam, with supports bolted onto that steel bumper specific for the lightning cover, and the 99-02 bumper brackets (only needed if you have a 97 or 98). You need all of those parts or else it doesn't bolt on. I purchased the bumper cover from a classified ad on the Lightning forums, it's an OEM cover, and got the supports from Tasca Ford, and for the steel bumper underneath, I found one locally on craigslist. I'll copy the pictures over and add some more details how it all goes together.
MISTERgadget
MISTERgadget
Miami
Next big mod was slightly out of order with the original plan, but since I have been collecting parts opportunistically, I ended up with all of this stuff in my closet, and it was just taking up too much space so on it went... and yes, I did feel kind of bad for making it "look faster" before it had the muscle to back it up.
Here you can see all of the parts needed for the Lightning bumper cover - Since I'm starting with a 98 I needed a 99+ grill shell, behind it you can see the Lightning bumper cover (just the cover) and behind that, a 99-03 F-150 / Expedition steel bumper. I painted the steel bumper with black VHT epoxy paint to try and keep it from getting rusty or pitted down the road. Behind the bumper itself, towards the right, you can see the brackets and supports that bolt onto the steel bumper to give it the shape to support the lightning bumper cover.
Here's a detailed look at what goes behind the Lightning bumper cover
I added switchback LED turnsignal bulbs and yellow foglight bulbs at the same time
MISTERgadget
MISTERgadget
Miami
New taillights went on around the same time as well. These export tails are very rare and I haven't seen them on any other expedition on the road, so I jumped on a new in box set that popped up. It's also a much more subtle OEM look compared to the ebay special LED tails.
At the same time, I also used some SEM bumper-coater paint to refinish the tan-colored Eddie Bauer bumper pads, eventually the chrome will be painted white as well.
The inspiration for these was the 1999 SVT Cobra, those came with export tails to distinguish them from other models, so if an SVT Expedition had been released around that same time, it may have also come with export tails.
For now, the amber portion isn't wired in yet and the red bulbs are still serving as stop/turn/tail, I've got the wiring diagrams here so I'll tackle separating the stop and turn portions in the near future. The basic concept is to take the stop signal that goes to the third brake light to the brakes, and then separate the brake switch from the turn signal switch under the dash, and then the existing wiring for the brake lights and turn signals becomes the wiring for just turn signals.
jmdunham2
