I've got a '00 EB 2wd 220k miles with a coolant leak that appears to be coming from the gasket at the front (psgr side) of the intake manifold. I'm told the gasket needs replacing. A couple questions, I could use your recommendations:
1) Is this something I can do?? I'm a novice, but have changed about every sensor & valve above the block by now. Realize this is a different animal. I do have some time this weekend!
2) Do I replace the manifold itself?? I've read they can pit & crack, but a local mechanic said he's never seen one that required replacement. Are damaged manifolds common on Expy's of this era & miles?
3) is it necessary to replace the upper & lower gaskets?? Leak seems to be coming from upper, but while we're in there...
Any suggestions would be welcome. Thanks!
