03 with a bad catalytic converter
rex450se
Independence, MO
I have a 2003 with the 4.6L that is throwing the PO430 code(Catalyst system efficiency below threshold Bank 2). Now I have read that these have a pre-cat then the cat and was wondering if anyone had a picture of the pre-cat? Can I just remove the pre-cat and replace it with pipe when I replace the cat? Does it in fact have a pre-cat or not? I am debating whether to take this somewhere or do it myself. Thanks in advance.
Victor
Hampton, VA
it not a pre-cat...we have 4...2 on each side and they sit in front of each other in line...not side by side
rex450se
rex450se
Independence, MO
Ok, thanks. Would I have any problems removing the front two and just having one on each side?
Victor
Hampton, VA
its called cat-delete...dont know which they do but its done
03expyMG
Nj
I have this problem. Found out today the rattling I thought was a heat shield when I bought the truck a few days ago is a drivers side cat. My buddy works at ford and found the after market one they use on the vehicles they service there. He told me 350 for the part. Better than the 1500 they want for the ford one. Mechanic said everything else looked very well cared for. Glad for that
jetmech06
Richmond Hill GA
I have a 2005 with 154,000 miles on it, I was getting a 303 code and changed the #3 cylinder coil, now im getting a po430 code. and somewhere I have a exhaust leak.. possible bad cat?
splintrcel
Milwaukee
My main Cat leaks so bad. Its splitting at the seam. I can tell because its getting cold up here in Wisconsin and i can see a lot of steam coming from under my car where the muffler is clearly not. No codes though. I really dont want to have to get a new cat so i will probably weld it.
FordandPolaris
Saint Cloud, MN
Guys usually hollow out the cat and then put it back in so that they can pass inspection. My state does not have emissions tests but I still have had a cop ask me if I have cats in my system (exhaust was louder than he liked I guess). You will get a code if the downstream o2 sensor does not read a change in the exhaust from the upstream o2 sensor due to the catalytic converter "scrubbing" the exhaust. As long as you leave one of the two cats on either side, it should be fine.
