xbid
My wife's 05 XLT 150k tranny and engine both new with less than 15k on them. Anyway she was driving it the other day fine no problem wasn't bucking or acting strange. Had plenty of gas etc. Gets back in to drive after being at a job site for a few hours starts moves about three feet and dies. Now it will crank but it won't start. Oil was low so I did a parking lot lube job before trying to tur it over too much so I didn't grenade the 5.4. Had it towed to a more appropriate work location where I managed to discover the joy that is the BLUE CONNECTOR and I will be putting a "how to modify fuel tank connector line after destroying your blue connector" guide up shortly. I'm thinking its a relay or the fuel mod. Haven't got a chance to drop the spare and look to see if the aluminum can is all rotted out, I spent all my "play" time learning how Ford ensures job security for it's mechanics. Seriously, put some more of the engineering muscle into power, performance, ride, economy, cancer research, ANYTHING but the fuel filter clip. I would be willing to bet 15 NASA grade engineers spent years developing that clip when whoever invented the hose clamp solved the "Fuel Filter Connection Problem" a long time ago. Anyway I'm hoping it's that or a blown fuse and not a dead pump. I really don't want to drop the tank and I heard the fuel moduel is mounted under the spare so i should check that first. Stealership has them in stock for a bill, part is OEM only. Line from tank does not pour gas when engine is key ON engine OFF, so pump is not running. Engine catches and runs for a second on a shot of quick start down the intake so I know it has spark. Dealer confirms key chip security gizmo of wonder not to blame as it does not shut down fuel delivery only retards ignition.
thoughts?
thoughts?
