08 stuck in park again
Dwspears
ga
08 stuck in park. If u reset with code reader it works for a few miles then wrench symbol comes on and when u stop it does it again. The code comes up position sensor. On this particular one the sensor is on the valve body in the trans. Last time it did this I just kept clearing it every time and finally stop and lasted about 8months. Now it’s doing it again. Thanks for any info.
El Dorado Hills, CA
My '11 got stuck in park because the brake pedal switch got flaky then failed. Ite gearshift wouldn't "unlock" when I stepped on the brake pedal. Super easy fix with $35 replacement brake pedal switch from AutoZone.
