Hi all I'm in need of some help.
I have no power to the trailer brake light specifically. I have running lights, just no brake lights or turn signal (same wire). I tested the wire before it enters the plug so its not a plug issue.
All the fuses under the box and in the kick panel are good.
The relays are working.
I suspect something with that wire has gone wrong, but I cant trace it from the front all the way to the back. is there a connection or specific area I should check for this thing?
Any help would be greatly appreciated!
