15 Expedition Platinum EL AC wiring diagram
xP8x
N. Alabama
Needing help with ac issue. Compressor won’t engage. All fuses seem good. Apply power to comp and it will pull in like it should. It has had an issues with the heated seats in the past, melted plug but that’s been repaired. Any help finding the wiring diagram or knowledge would be greatly appreciated.
Hamfisted
Ft Lauderdale
Do you have a AC system pressure gauge set ? See what the low and high pressures are in the system. There is a low pressure sensor that will prevent the compressor from engaging if the system is low on freon. But I've attached the AC circuit diagram to this post just in case.
Yellow Jacket Manifold Set on Amazon
  • Expedition Gen3 AC Circuits.pdf
