ChrisOIFdoc
Timing chain
Timing chain
Just curious Chris, but why do you think timing chain? Because of the marble noise or the codes? Honestly curious here, not trying to be an ass or anything, just wanna pick ur brain.Timing chain
For the op...I had a similar issue with my 99 expy... sputtering, loss of power, engine was "loping" (personally I call it surging, the p.o.s mechanic called it loping) etc, threw the 1401 code and 2 codes for upstream o2 sensors, and a code for misfire on cyl 4. The p.o.s mechanic tried convincing me it was intake gasket (personally I think he was after the $700 gasket job but really knew it was pcv line). After replacing the 02s and the egr valve (needed done anyway, it was cheap and they were original parts with 230k on them) turned out to be a vacuum issue. Replaced the pcv line and voila, ran like a champ. So the p.o.s mechanic was right on 1 point, it was a vacuum issue but no where near as bad as the intake gasket.
