!!! 200,000 4.6 triton preventive maintenance suggestions !!!
Eddie Lanham
West Palm Beach
So my 04 eddie bauer expedition rolled over to 200,000 miles today and i was wondering what i should do to keep her running even longer... any suggestions are helpful! i have the money to put in to the vehicle (as of right now lol) so im all ears!!!! thank you!
Habbibie
Is it Christmas yet?
Chicago
Fluids changed out
Thermostat, Water pump & radiator hoses
Clean out MAF and throttle body
Not really a lot of to do's if it's running good
johnboneske
Ohio
When is the last time you did plugs? I change mine every 100k and always use Bosch Iridium plugs. Just my personal preference.
ExplorerTom
Colorado
I'm at 233k miles. Haven't really changed any kind of particular maintenence interval since I went over 200k. Just change things as needed. Be attentive to any noises or hiccups and address them right away. Keep the fluids clean.
Ltmax
Jacksonville FL
I'd get the upper/lower intake manifold gaskets changed out, by that mileage they are sure to be rock hard and not completely sealing anymore. I'm sure they'll discover a few other vacuum lines that are either leaking or just about to go bad while it's apart that will ensure another decade of trouble free driving. The two cooling passages that go through the intake gaskets are also very prone to leaking so this will prevent that as well.
Also it wouldn't hurt to replace the two upstream Oxygen sensors as they are probably getting pretty lazy by now if they are original causing the PCM to work overtime trying to maintain optimal fuel air mixtures.
Ltmax
Jacksonville FL
Also if you want to triple the life of your transmission you can get a trans expert to drop the valve body and install a super tuff separator plate, zip kit, and new overdrive servo pin kit. That will eliminate all the common failure issues that kill these otherwise rugged transmissions.
Ltmax
Jacksonville FL
Here are some pictures of the last 4.6l intake gaskets I did a few months ago on one with 190k miles that wasn't leaking coolant yet (but was just about to) and was running pretty poorly due to top end vacuum leaks.
E
Eddie Lanham
West Palm Beach
the bus
Everything that everyone else said;) fluids, vacuum line especially the big elbow one on the back of the intake, cops, plugs, fuel filter, maf, throttle body, and I cleaned the idle air control too. I have had some battery issues over the years and it is a good idea to wash that area and battery down with baking soda. And the biggest thing is to take care of any cel especially any miss fire codes!
