2000 ford expedition solenoid location
z001psz
iowa
im looking for the solenoid for my 4x4 on my expedition its stuck in 4hi replace transfer case motor still stuck need check solenoid, found a solenoid under throtle body, when unhook scanner says emmision evap, and theirs one solenoid by driver side firewall but no double vacuum hose to it, all videos i see have to solenoids one for 4x4 and one for 2hi, any one know where this is the net just shows pictures of other trucks and other peoples post just say by the firewall and i dont see any thing thanks
stamp11127
Temple, Georgia
From the factory service manual for your problem:
The vehicle does not shift between the different modes correctly:
Mode switch.
Wiring/relays.
Shift motor.
Transfer case.
GEM
Symptom chart:
The Vehicle Does Not Shift Between 4WD HIGH and 4WD LOW Modes Properly
4WD mode switch/circuitry.
CJB Fuse 23 (10A) and 20 (5A).
OSS sensor.
BPP switch.
Transfer case shift relays.
Transfer case mechanism.
CJB.
GEM.
DTR sensor.
Z
z001psz
iowa
looking for the solenoids no one know where it is?? i just want to check the vacuum on it!
Bedrck47
Elizebethtown, PA
The solenoids you are looking for DO NOT EXIST on the 2000 expedition That is why you can not find them They are needed for the 2wd system which you do not have Look at the switch on your dash It should show AWD 4 Hi 4 LO
Read my reply in your other thread
