2001 4x2 expo
drew26
pasadena
can i run a 285/70/17 on my stock 4x2 e b expo and also i have a miss fire in the engie but no engine light on please help...:troll:
mohs00
michigan
yeah you should be able to run that tire size with no problem as far as the misfire goes have advance or auto zone scan it any way even if the check engine light isnt on the code could be a soft fault so it might not trip the engine light.... otherwise put some new spark plugs in her and see if that takes care of it
D
drew26
pasadena
i put a scanner on it it should up with nothin just put plugs in her thinking it would help , helped some ,
D
drew26
pasadena
285 70 17
hell yea i puit the nitto dune grabblers on my expo looks sweet still having trouble with m,y factory radio any help why my factory sub ist working???:troll: :troll: :troll:
Tech
Massachusetts
Just gotta keep drivin' it till the check engine light comes on. Easiest way to determine what coil / plug it is. Trust me, I have been there and it sucks. :(
Grasshopper
Moore, OK
Have you had it looked at by a mechanic? Sometimes they read the truck's mind and tell you right off what it is.
r98exp1
