2003 XLT 5.4 FUEL LEAK WHEN FILLING UP ONLY
SEPTIC PROFESSOR
SARASOTA
When I fill up all the way, there's a profuse gas leak which occurs but ends in a minute or so.
Has anyone had first hand experience fixing this yourself and if so were there any parts that
needed replacement ?
Thanks in advance.
1955moose
He's on the right forum, just turned out nobody had similar issues!
BRIANGEE
AZ
Sounds like the filler neck has deteriorated.
Adieu
SoCal
Look under truck under the panel, its probably just the filler leaking and not the tank or fuel system.
rjdelp7
2000 XLT
NY
You may be pumping gas, into charcoal canister/evap system. One or two clicks only.
