2005 EB transmission line leak?
Boston MA
I have a trany line leaking on the radiator connection. The part that goes into the radiator is that available? I also need the special line tube to disconnect them. I purchased a dorman line replacement kit and then I looked at the connections and closed the hood and ran.... 250,000 miles of salty roads...she is verry crusty underneath but amazingly very dependable.
Hamfisted
Ft Lauderdale
E
Boston MA
The trans line tools are usually available at any autoparts store. Or you can just order online from Amazon.
https://www.amazon.com/Lisle-39960-Transmission-Cooler-Disconnect/dp/B000TQ6P40
This should be your tube connector.
https://www.amazon.com/Ford-YL3Z-7D273-AA-Connector-Oil-Tube/dp/B01EO40ZRU
If it's time to replace your radiator, a new radiator will come with new oil tube connectors already in it. Might be worth considering.
The expy has 250k and the radiator dosent leak or looks bad, even in the summer at 90 degrees i was pulling a 3500 lb trailer and the temperature gauge was great. But I will have a good look at it and if need be I will replace the radiator. Thanks for the reply
