That looks just like my 2008 PATS key, any locksmith should be able to cut it, but you will need to go to a dealer to get the car programmed to recognize it. You can go to ACE or somewhere similar and they will cut and program a key for you (car doesn’t need to be programmed) but they won’t program a key that you bring to them. ACE charged me $70 for a new blank and to cut program the key. Each genuine Ford key has a programmed code inside and the car has to be programmed to recognize the new key code, Ace, Walmart, etc have a blank key with no code and they have a machine that reads the code in your existing key and then programs the exact same code into the new key, this way the car does not have to be programmed as it already knows the original key code.. hope that helps.
