2008 - Thumping noise coming from rear AC/Heat unit
nathan faught
HSV
I just got into my wife's 2008 tonight and when I cranked it up and turned the radio down I could hear a small thump coming from the AC/Heat unit in the back on the passenger side.
I took the tap tray piece off and the cup holder out but still cant pinpoint where it's coming from.
What could be causing this. The AC and heat still seem to work as expected so is this anything hurt by this thump/click and how difficult is this to fix?
Thanks!
Bedrck47
Elizebethtown, PA
Sounds like you have a bad Temperature Blend or Mode Door Actuator. Easy to replace. Look on youtube for videos on how to replace it.
Bedrck47
Elizebethtown, PA
Only harm is listening to the thumping But you can check it and find out which actuator is at fault and disconnect the connector
Denethor
Durham, NC
Or you can slightly adjust the temp to that zone, so it stops trying to move the blend door to the bad spot on the gear (it can't anyway). Like on mine, just not cranking it all the way to cold (I just go to full cold, then back off one click of the dial it stops the thumping). The only 'harm' is the door can't move past the broken tooth on the gear (the thumping you hear is one plastic gear tooth slipping past another) and the temperature coming out of the rear will not be as hot or as cold as it could be.
Bedrck47
Elizebethtown, PA
That would work for the temperature blend door but not for the mode door And the OP never stated which door was doing the thumping.
N
nathan faught
HSV
I'm not quite sure which is thumping. But if the fix is only $100 or so, I might as well do it just to have it working properly.
My wife would never even notice things weren't working most likely...
Bedrck47
Elizebethtown, PA
There are two actuators the one towards the frond is the mode door it directs air to the floor or to the roof vents The one towards the rear is the temp blend door Check on rock auto for the parts But they may be different due to the wheelbase of the model you have. May be best to just pull the bad part and get the part number off of it and that way you will get to correct actuator.
Check the video on youtube and having the wrench that the Ford tech uses is very helpful
On my 04 both actuators are bad I currently have them removes and wired the doors to the position I need them to be in.
When I get the new parts I will install them Most likely when the weather get better In the meantime I now have plenty of heat in the rear of the expy and no thumping noise
