3.31 or 3.73
montecarlo31
Hey guys would 4.10's really be good for a 06 exp. with the 5.4? I mean what will the take off feel like? do you have to upgrade the bearings and other things?
Ring and Pinion, plus the nut at a minimum. I would overhaul the entire rear end and front end if I had any significant miles (over 100K).
4.10's is a low gear what's the PROS and CONS?
Pros:
Improved acceleration
Improved multiplied power (IE feels like you have more power under load)
Depending on tire size improved fuel economy.
Cons:
Higher engine RPM on highway
Depending on tire size decreased fuel economy.
If you are jumping from 3.73s to 4.10s I would probably advise against it however if you are going from 3.31 or 3.55s I would say it's quite a noticeable difference.
I would use only OE gears if at all possible, I've run a lot of different brands in the past and even when they are set up properly you can still get noise that isn't present with the OE Ring and Pinions.
AbelNavyvet
Weslaco
when I swapped out from 3.31 to 3.73 there was a 15 Lb. differ. but the difference was felt.
