4-18s audio build
Hampton, VA
New subs being built... custom 4-18s by deaf audio to be put in end of month... over 100lbs...4k rms each94f9f3cbc2a14d7fc811b339a8903a43.jpg
Sent from my SAMSUNG-SM-G935A using Tapatalk
Hampton, VA
Finally finished with the build... swapped skar audio amps out for these wolfram audio amps for subs and doors...4-4500s and 4-125.4s amps...22K watts!!! 2 northstar 480 agm batteries and 3 apex high output 370a alts...4 PAP 4K watt subs...8-6.5s...4-8s...4- bullet tweets and 8 regular tweets... front and rear volt meters 20779141f8229be87a9a1e10381d385c.jpgacbf5f7e4a927e595cd60d926d2f0fda.jpgedf92ccab86dc80736494dfdff5a1145.jpg893804bb0e479b33aa4df5b900fa1a23.jpg3c82dd8ecb653e350389ba7a0a3214cb.jpg
Sent from my SM-G965U1 using Tapatalk
Trainmaster
Old School Member
Rockaway Beach, NY
The work you did on the panels is excellent -- and that's coming from a very discerning guy. You can be very proud of your work.
Hampton, VA
Thank you but everything wasn't done by me... can't take credit for doors... my design but I didn't build them...I will build my next set tho...
knewblewkorvett
Iowa
I'm impressed but confused too. I only count 3 subwoofer amps in the picture, got one amp hidden somewhere? So what the SPL? Are those white cans fans?
Hampton, VA
The top amp is the 4th and the 2 under that are double stacked...4 big amps and 4 small amps
r98exp1
