The reason that I am asking ? It is also my understanding that the rear axle runs at a different speed than the front ? this makes sense from what I have read ( if there is no give ) would cause torque wind up , they work against each other ? I will just keep playing it safe from a stop , off road .
The front and rear gears run the same ratio. Even in 4 low it runs the lower ratio to all 4 tires. The problem lie when you try and turn or if the front and rear tires are worn differently.
