99 Expedition leaning like a lowrider
Nasanieru
Stuart, Iowa
Hey Guys,
Ok, Maybe not leaning that bad. But, It is leaning twards the passanger side.
I purchased a conversion kit for the air suspension and had it installed. I thought that it started out level when It was first put on. But 2 weeks later it is leaning. The truck rides good though, suspension doesn't sound like the shocks are leaking? Don't know what to do about it?
Thanks for any help...
Nathan
FordandPolaris
Saint Cloud, MN
Post a picture if you can. Does the spring on the passenger side look more compressed than the one on the driver side?
walnuts4x4
Watertown, NY
I would start by measuring the springs and see if one is more compressed than the other
Thermo
technical advisor
Nathan, crawl under the front of your truck and look at the sway bar link. I bet you will find that the bolt that ties the lower A-arm to the sway bar is broken. A trip to your local auto parts store and about $15 will get you a new link setup. That should fix your leaning issue.
