So haven't gotten a whole lot done but do have a little progress. I replaced the water pump, rad, thermostat and housing, over flow tank cap, rad hoses, both heater cores, front blend door and actuator. while i had the rad and other things out of the engine compartment I had a little rust on the lower rad support so I sanded it all down, primed it with adhesion promoter, por15ed it and used a flat black over coat just to nip it in the but before it had a chance to get out of hand.
When I took the dash out to get to the heater core I found all sorts of hack job wiring. Its bad. I think it is all from the car starter/ alarm. The alarm just fell out in a waded up heap when I removed the support frame that holds up the steering wheel. SO the dash has been out and even with out the bad wiring I can tell because bolts are missing and miss matched. The pass air bag was only held in with one bolt... very safe. I went to the junk yard and got some bolts out of an f150 just to help prevent rattling for the huge system I'm putting in.
i don't have the dash put all the way back together yet. I'm not completely confident that the front heater core and quick connects are not going to leak. The connection tubes are like an 1/8 inch longer and the quick connects would not fit no matter what I did. I found a hard plastic ring inside the connectors closest to the outside that wasn't even big enough to fit around the tube and the stock ones didn't have them so I took them out and finally I could get them on. what a huge ***** that was. Also I am using second skin damp pro and luxury liner pro up in there where I can.
Yesterday I started to tackle the big 4 and my mechman alt install
