Toman-Sager
I am having several issues with my 2014 Limited.
1. My check engine light is on displaying P0017, P0365, and P0369.
I have replaced both camshaft position sensors and the crankshaft position sensor and the codes persist.
2. My ABS, TCS, and other brake related lights are on.
This started happening after I had a tread separation occur on my back passenger tire. The wheel speed sensor is reporting the same values as the others.
3. There is a little bit of shaking occurring when i am braking hard or when going down hill and braking.
I believe this is coming from the front driver's wheel.
4. My vehicle runs rough at idle and at little power applied.
I gets smoother when I apply more power to it.
I did a scan with FORscan and this is the result. Some of the sections with no faults have been deleted.
Here are the things I suspect are the issues:
1. and 4. may be a bad/loose timing chain.
2. and 3. may be a bad wheel bearing/hub.
Am I even close? What can I do to verify and fix these issues?
