Abs light just came on?
FordandPolaris
Saint Cloud, MN
Probably either damaged/unplugged a wheel speed sensor or got water where water doesn't belong. ABS light indicates the system is simply in off mode for now, so it is drivable. Check wiring going from the wheel hubs in front and back.
Hampton, VA
check the module where the lines go in at...when mine came on it was leaking from there
Hampton, VA
my abs module went bad without the brake light indicator on dash...just saying
FordandPolaris
Saint Cloud, MN
You probably caught it early before the fluid got low enough for the sensor in the master to turn the brake light on. It has to be pretty low to get the light. Air in the lines (or ABS module) will not turn on the brake light if that makes sense.
Junker
