WPG2013
Check for brake fluid leak too
Mr. 10K
Changed out the sensor, no problems since. Can't see any fluid leaks.
Mr. 10K
OK. so I had something similar a while back. The main thing that caught my eye is when you state you are pulling a trailer. I had the same issue with the ABS coming on. Months of investigating and it ended up being the gear and pinion in the rear diff was completely broken (only after a heavy, long haul tow). Drove around for quite some time with it broken and had no idea. Pulled off the rear diff and the gear was completely broken.
