Adaptive Cruise Control
deemjay55
Detroit
New here. I picked up a Limited Stealth 304A. I have the 12in screen. Does anyone know how to change the Adaptive Cruise Control Gap?
D
deemjay55
Detroit
Yes. From what I gathered, you are to press the ACC button to adjust the gap. When doing so I, can't find the gauge that accounts for the adjustments.
AJ82
It looks like it displays the bars between your car and the one you are following
D
deemjay55
Detroit
Good point. So this seems to be a setting that only be adjusted while being used. I did read that the last setting selected remains until changed. Thanks for the help. Once I figure it out I let the group know.
D
deemjay55
Detroit
I have confirmed the setting has to be adjusted while using ACC. Thanks for the guidance.
There are a lot of features on this truck. Lots more to figure out.
CassRose47
Oklahoma
How is the sport suspension?
Following!! I’m between the 303a and 304a and don’t want to order/commit until I hear about how they ride. Can’t find one to test drive. Currently soccer momming in a 2018 ltd max and worry I’m going to bounce around in the SPP!
mdecillis
Iselin, NJ
There is a button on the left side of the steering wheel that adjusts the gap while using the ACC. See attached.
mdecillis
Iselin, NJ
Definitely feels stiffer and more responsive than my 2019 stealth. I think the 304a is worth it because you get a lot of stuff with it, dual exhaust, painted calipers, 22 speaker stereo (although it seems like they removed that for 2023 MY :confused:).
