Aftermarket Sub - Use factory location or a separate box?
synapse888
I was planning on replacing the entire stereo system in my 03 EB Expy. Is there any way to put in an aftermarket sub into the factory location and have it sound fairly loud? Or would I need to proceed with a box in the back instead? I tried to hunt around for any threads on this topic but came up empty mostly...so please link to any prior discussions.
Thank you!!
whtbronco
Winchester, VA
The problem is "fairly loud", that's extremely subjective. At 20yrs old my perspective of fairly loud was much higher volume or harder hitting than it is almost 30yrs later. I plan to make a custom sealed box and install a 10" sub with 400watts. I expect it to be far more than I need/want. I do not want to advertise what's in my vehicle I've had plenty of stereos stolen in years past. I just want good, clean, full sound that stays inside my vehicle.
Here's an article on doing this:
https://www.expeditionforum.com/threads/full-stereo-system-build-pics.11014/
You could more than likely put a 12" sub in the factory location if you can find one that will work in a 1ct ft box or less. To get 1cu ft you'll have to use every bit of available space in the factory location though.
If you want something seriously loud and hard hitting, you wanna be hear down the street, you'll need to use multiple subs and/or a large box outside the factory location with a big amp I think.
oblivion
Ontario Canada
Stock location with a custom enclosure you can get a 10" so sound amazing with no impeding space in the truck
