Airbag Light
TD111999
I have recently revived my 06 Limited after it sat for 5 years. When I got it running I noticed an airbag light. The light does not flash a code upon startup like it should, from what I’ve gathered. If I put the gauge cluster into engineering test mode it shows that the drivers seatbelt is always buckled, could this be the cause of my light?
Trainmaster
Old School Member
Rockaway Beach, NY
Yes it could. I would solve that problem first. Fix the switch or wiring. If the light persists, you need a "Ford enhanced" code reader that will direct you to the precise problem. Welcome here, by the way.
Hamfisted
Ft Lauderdale
If you have ForScan on a laptop it'll read and clear the code(s). Maybe spray some WD40 in the seatbelt buckle and work it a little to free it up. Then see if the code comes back.
