Does anyone know what the alignment specs should be for a 2004 Ford Expedition NBX (Offroad version of a XLT)?
I just changed the springs and shocks to Rancho QuickLifts (they are great BTW.)
Here's the issue. I'm getting excessive wear on the inside of the tires, I have been to two shops the last 6 months and they both say it's within specs. I'm concerned about my camber adjustments.
I went into Les Schwab today to have it looked at, and I specifically asked them to fix this issue, because I can visually see how off the wheels are. All 4 were tipping in, noticeably, they did fix one wheel, but all three others are off.
Front Left is:
Camber -.9 (specs say -1.1 - 0.5)
Caster 5.1 (specs say 4.3 - 6.3)
Toe .12 (specs say -0.03 - .17)
Front Right is:
Camber 0.0 (specs say -1.1 - 0.5)
Caster 5.0 (specs say 4.3 - 6.3)
Toe .03 (specs say -0.03 - .17)
Rear Left is:
Camber -1.1 (specs say -1.7 - -0.2)
Toe .17 (specs say .0 - .2)
Rear Right is:
Camber -.9 (specs say -1.7 - -0.2)
Most of the setting seem to be at the tail end of the specs. Should I be concerned with this, especially when I still notice a visible tilt in on the tires?
Any suggestions would be helpful.
Thanks
Front Left is:
Front Right is:
Rear Left is:
Rear Right is:
Thanks
