A dealer that "believes" it is the pcm vs one that proves beyond a doubt it is the pcm tells me they don't know and are guessing. They need to prove the pcm failed before condemning it. They would have something such as "unable to communicate with the pcm" when they try to diagnose it. Or during diagnosis there shows no output to the injectors.
Basically a more informative proof of failure before tossing parts at it. The following is from Fords Service Manual for 2007 for replacing the pcm:
Removal and Installation
Retrieve the module configuration. Carry out the module configuration retrieval steps of the Programmable Module Installation procedure. For additional information, refer to Section 418-01
Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
Disconnect the 2 PCM electrical connectors.
Remove the 2 bolts and the ground cable.
To install, tighten to 7 Nm (62 lb-in).
Remove the PCM.
To install, reverse the removal procedure.
Installation
Install the PCM.
Position the ground cable and install the 2 bolts.
Tighten to 7 Nm (62 lb-in).
Connect the 3 PCM electrical connectors.
Connect the battery ground cable. For additional information, refer to Section 414-01 .
NOTE: When a new PCM is installed, the air bag warning indicator will illuminate when the ignition switch is ON. The warning indicator will remain on until PCM configuration is restored
NOTE: Clear all restraints control module (RCM) continuous diagnostic trouble codes (DTCs) after Programmable Module Installation procedure has been completed on the PCM.
Restore the module configuration. Carry out the module configuration restore steps of the Programmable Module Installation procedure. For additional information, refer to Section 418-01
So if they say that they were unable to download the configuration I would ask they if they verified it was getting power. If they did then yep it is toast.
Remove the PCM.
Installation
Install the PCM.
