98EXPY 5-0
Ok, so a few years ago the front spark plug on the passenger side (closest to radiator) blew out. I found out it already had an insert and had simply unscrewed. I put it back in with red loctite and all was good for a couple years. Then it blew out again, but I couldn't find the plug. I took it to my mechanic and he drilled it for an even larger insert, and put a new plug in. It ran a little rough and after changing the coil twice, I determined that it was not the coils. So I took it easy while driving for over a year now. Most days it runs ok, but some days hills are a struggle.
This morning the second plug from the radiator on the driver side blew out.
I could have a standard insert put in, assuming it isn't too screwed up, but I'll still have the original side causing me issues.
I can't afford to just go buy another truck. I'm debating whether to have the heads pulled and fixed, or pulled and replaced with junk yard units, or maybe getting a junk yard motor put in.
Either way, I'm probably not going to be able to do it myself, because I don't have anywhere to work on it that's indoors. I've also never tackled a job quite so large as to pull both heads.
Any thoughts? Suggestions? Winning Lottery numbers?
2000 Expedition with 201k miles. 4.6L
