Anyone replaced motor mounts?
2004XLT
CT
My exp needs the motor mounts replaced..I couldn't find any good info or videos about replacing them. I just took a look under and there's almost no space to access the bolts that hold mounts to the engine. I want to tackle it myself but I don't want to go into it blind. If anyone has any pointers it would be much appreciated, even if it's for a first gen expedition. Thanks guys.
tcwaltz
Niceville, FL
The drivers side will be tougher than the passenger side but this should be doable. Its only 3 bolts per side. Its more difficult on the drivers side because of the ABS module and brake lines and hte power steering lines, but some of that can be moved out of the way. Biggest thing to do is remove the fender liner so you can gain access.
Junker
