Automatic Running Boards
bloodhound
Merica
I have a 07 Expedition and I am also looking to switch to power running boards. It looks like all that is needed is the module in the b-pillar and wiring harness for each side then turn the feature on. You might need ForScan. I am willing to trade someone my static running boards for their power ones.
Bring 'em on up to Massachusetts.
wk99
Purchased my 2012 EL Limited brand new and has 178k miles on it. I haven't had any issues with the automatic running boards. I spray it down with WD-40 every so often to keep the joints from ceasing up. I occasionally see people riding around with one or both fully extended and think, dang if they only watch a Youtube video they can fix it by spraying some PB blaster on it..lol. No way would I go to the dealership and let me charge me an arm and leg for a simple fix. Heck, I just recently did my own timing job successfully and it was the first time going into an engine..
bloodhound
Merica
I've been using this stuff, it is a really good deep penetrating lubricant (hence the name).
2013Tuxedo
Minneapolis
If they are really bad it's a lot more involved than penetrating fluid, mine are currently off and torn down and getting a full lubrication. Currently deciding between doing the self-tapper mod or fitting a grease Zerk.
Huggyb1972
Indianapolis
You can buy parts to repair them if they need it. I found a set off a short wheel base limited and put on my Eddie EL. The wiring I have no idea factory wise. You could probably find or build a control for them pretty easy.
