studabaker
My transmission went out and i had a used one put in by a salvage company and the one they put in was from an eddie bauer and I was just glad to be able to work more but now two years later I am glad it is still holding up but there is vibration from the transfer case and it turns out I was in 2wd the entire time. The other problem with that is that is the rest of my vehicle is not eddie bauer inckuding my awd selector switch which does not have 2wd and only awd, 4wdh, 4wdL. I had changed it to 4wdh to regain awd for winter and this is when the transfer case vibrates on freeway speeds.
My question now is if i get a eddie bauser selector and put it in 2wd or awd and then replace my transfer case and front differential, which seem to be worn out now... should it stop wearing them out or do i need to replace front differential with eddie bauer. Are there any differences in those parts from two models. I know theres an oil cooler in the eddie bauer transmission that i dont know how they solved that maybe a bypass... because im pretty sure i didnt get a new trans cooler.
In 2wd now theres minimal vibration. Barely noticable.
Maybe this is more of a transmission shop question and i will report back on the results for your information.
