wpatters1229
All of a sudden my 2000 for exp. started having battery issues. It will lose a couple of volts and be down to around 10.5v. It will barely turn over but just enough for it to start. Then after letting it run for a minute or two it starts just like normal. I have looked at AC voltage while it is running to see if the alternator has point diodes and AC voltage is around .025 which is good. I looked at current draw and while pulling every fuse and relay the current draw did not ever change and was pretty steady about 2.5 to 3.0 ma. I have read that sometimes there is a problem with the starter circuit or the starter relay drawing down the battery? OR is this just a battery that is going bad?
It is also weird that after you run it for a while and it shows a full charge it then starts to slowly lower the voltage until it stops are around 10.5 v and just stays at that level. Maybe what I am seeing is a bad cell that is leaking down? It is a sealed battery so I can not check each cell.
Advice Please..
Advice Please..
