Bowesmobile
That's temp is usually 210-215 degrees. So a switch rated around there will work great. I sized my thermostat a little cooler to 185 deg. and sized the switch to match.
Well I ended up using a different pwm controller from Hayden, so far it works well! Only thing is it'll only control one of the fans due to amp draw so I have it hooked to the large one. Will post more updates soon...
With the stock thermostat, what temperature should I set the fans to come on at?
