Best thermostat brand & temps
BANGEREXPO76
PLUGZONE 76
Guys,
What kind of thermostats are you running?
What brand and temp works best for the 5.4?
Banger
Hampton, VA
jet performance...i think its 90 or 110 degrees...dont remember
1997SCEBFEX
Northwest Panhandle
Specific brand is your call IMHO as there are lots of manufacturers out there.
I used a Duralast 15119 from AutoZone; rated @ 195*.
Thing to check when changing is whether or not you get a new o-ring in the box as when I did mine it only came w/ the rubber seal around the flange and looked as if it would leak vice the factory o-ring.
Last thing is proper torque of the bolts.
toms89
technical advisor
MD
Might as well not run a thermostat if its that low.. :p
Stock lightning stat for me...what ever that is.
01yellerCobra
San Diego
Re: Best thermostat brand & temps
I usually stay with the stock temp stat unless there's some major mods done.
Misspelling brought to you by Tapatalk
Exia
Kentucky
I use 160 in all my vehicles, but with the failsafe option.. they are a bit expensive but just incase of a over heat, they are mans best friend
BANGEREXPO76
BANGEREXPO76
PLUGZONE 76
Tom89, Freeway, Superexpy,
Thanks for the replies.
Just wanted to say you boys have some very cool machines. :happy160:
Banger
Tan Khai Nguyen
