Thermostat housing bolt size
Tim S
Replacing the thermostat but one of the housing bolts is stripped. Seems to be a flanged 10mm x 100mm. Having trouble finding that size with the flange. Is there a part number for this?
whtbronco
Winchester, VA
I couldn't find a part # for you. That said I just hit up the local salvage yard for bolts. They don't even charge for bolts around here. Might be an option for you that you could get a little faster. Otherwise I'd hit up the local dealer.
