Terrible front end bounce at any moving speed, including reverse and 4wd High and 4wd Low.
Front end is also very stiff and will not bulge when trying to bounce on it while it is parked.
This all started directly after replacing driver side CV axle. Used the original axle nut as well as the one it came with, still have the problem.
It also seems that my upper control arms are rubbing on the frame, but if this is the problem, then how could it have happened so suddenly just after sitting in the driveway and having the axle replaced?
The axle nut has been torqued to 150LBS and 175LBS
Working on putting the original busted axle back in to see if I purchased a defective one.
EDIT: After replacing the new CV axle with my OEM one, the problem seized.
Does anybody know of a good brand or where to purchase an axle where this problem won't occur?
