Brakes
JTKustoms
Boston
Hey guys so I'm getting my truck back out for the summer, been neglecting her since I bought a challenger. So my brakes are extremely bad from driving on 26's, front pads are almost totally gone if not already gone. Does anyone have any experience or tips about replacing them? Doesn't look to be too complicated but any tips would be helpful. I plan on replacing those then bleeding the system if I need to because the pedal has been real spongey since I had a few lines replaced 2 years ago
F1vel66a
Salem, Or
If pedal is spongy bleed them. But it isn't complicated it's only like 4 bolts per and if you can use ceramics. Autozone offers a lifetime set for front and rear. They replace for freer when there worn down. Think front and back is like 100 total. Anyways rim. slide through bolts 2 bolts in back behind caliper them it falls off push the piston back in (open bleeder valve since you're bleeding Anyways) install pads. bleed in the order of rr, rl, fr, fl. Farthest from booster to nearest.
Stoned06
Milwaukee
Lubricate the guides pins/slides, as well as the pistons to make sure you don't get a seized caliper. I recommend brakemotive on ebay as a seller. $205 shipped to your door for cross drilled/slotted rotors, with ceramic pads.
FordandPolaris
Saint Cloud, MN
You will need a torx drive (no idea the size) to remove the two mounting bolts/slides. Also need a c-clamp to compress the pistons again. I just use the old brake pad to do this. I picked up my ceramics from O'Reilly. I like them a lot.
Spongy pedal can also be a master cylinder. I just did mine about 3 months ago and that helped a lot. I agree though, bleed them first to eliminate the line work from the problem.
alaskanexpy
anchorage alaska
its been a year since i did mine but i thought it was a allen head bolt? anyhow thats the only part that through me for a loop.
i have cyro treated power slots on my other truck and one day i'd like to put them on my expedition also.
FordandPolaris
Saint Cloud, MN
I could have my names mixed up. Whatever the star pattern is what mine needed. Best thing to do is just take a quick peek with a flashlight to see what style to look for.
