I keep finding transmission fluid on the driveway and the Y-pipe always has a drip on it.....pan is tight but it just keeps leaking. Happens when parked for an hour plus. It’ll be dry and about 2 hours later if parked and not started there will be a few drops on the ground. You’d think output shaft would only leak when spinning so not sure where to go here. Right now the leak isn’t worth going after and I’ll add fluid, but I can’t for the life of me source where it’s coming from.
