Blackwater
I have found that the earlier model of Grand Cherokee and the first generation Tjs shock coil spacers will fit the rear on the coil mount and coil of Expeditions. They are only about ¾” But can be stacked So you will need 6 to 8 of them.
For everyone that has a pick and pull junk yard you can get them cheap and a lot of the times will find a jeep without the front axle so no work to get them...The junk yard near me only charged $5 for 8 of them.
As for stacking and to be on the safe side I will be welding on a 3” to 4” steel pipe in the middle of the coil mount to slide the spacers over so three is no chance of it slipping even though the spacer slides in to the one above. The you have the advantage of being able to dialing the rear with 3/4” adjustments.
