IMINYOURCHAIR
started the expy after work today to pre cool it while I did paperwork after work. walked back and it was still 110f and I happened to hear the ac clutch kick in. I have an ac bypass switch to disable my ac since it doesn't kick out on WOT and this switch has a light, it is wired in series to the high pressure switch with an led. this led was out and came back on a minute or so later then I thought to check the fan. it was turning maybe 10% of the shaft speed and the temps according to torque were at 225f. everything came back to normal when I started driving and the ac leveled out at 48f vent temp after 20 mins at max ac and max fan. fan spins easily by hand with truck off.
Anyone here had to replace the clutch assy yet? what brand did you use.
