Strongly suggest you listen to stamp11127
VERY Strongly suggest you disregard advice from post # 2 as it does not apply to your problem
Also it is always nice to know the year of your expy when asking for help
The following was copied from the 2006 Ford Expedition Service Manual
P2106 - Throttle Actuator Control (TAC) System - Forced Limited Power
Description: The TAC system is in the failure mode effects management (FMEM) mode of forced limited power. This DTC indicates the FMEM action is in effect due to a concern in an electronic throttle control (ETC) related component or module.
Possible Causes:
- Unplugged motor, circuits short to voltage
- TAC motor open, unplugged motor, circuits short to voltage
- TAC motor stuck open or closed
- Mass air flow (MAF) sensor concern
- Throttle position (TP) sensor concern
- Module communications network concerns
- Manifold absolute pressure (MAP) sensor concern (vehicles with an EGR system module [ESM])
- Output shaft speed (OSS) sensor concern (Crown Victoria, Expedition, Explorer 4.0L, F-150 5.4L, Grand Marquis, LS, Mark LT, Mountaineer 4.0L, Mustang 4.6L automatic, Town Car)
- Turbine shaft speed (TSS) sensor concern (Crown Victoria, Expedition, Explorer 4.0L, F-150 5.4L, Grand Marquis, LS, Mark LT, Mountaineer 4.0L, Mustang 4.6L automatic, Town Car)
- Anti-lock brake system (ABS) concern (Crown Victoria, Expedition, Explorer 4.0L, F-150 5.4L, Grand Marquis, LS, Mark LT, Mountaineer 4.0L, Mustang 4.6L automatic, Town Car)
- Transfer case mechanical concern (Expedition, Explorer 4.0L, F-150 5.4L, Mark LT, Mountaineer 4.0L)
Diagnostic Aids: This DTC is informational only and it may be accompanied by other DTCs. Diagnose other DTCs first.
Application Key On Engine Off Key On Engine Running Continuous Memory
All GO to Pinpoint Test
QE .
P2135 - Throttle/Pedal Position Sensor/Switch A/B Voltage Correlation
Description: The powertrain control module (PCM) flagged a concern indicating that throttle position (TP) 1 and TP2 disagree, or that TP1 should not be in the present position given the position of TP2 unless a concern is present.
Possible Causes:
- TP sensor shorted internally to VREF
- TP sensor harness is shorted to voltage
- TP sensor signal wires are shorted together
- Damaged TP sensor
Diagnostic Aids: Compare the TP1 and TP2 PID values for a full sweep and correlation. Refer to the chart in pinpoint test DV. GO to Pinpoint Test
DV .
Compare TP1 and TP2 PID values to the typical reference values in Section 6,
Typical Diagnostic Reference Values .
DV .
