Codes - 2004
Aaron stowe
Allentown
I have codes p2196 p2197 and p2198 can u tell me what parts need to b changed? I also have codes p0300 p0306 p0307 p0308
sjwelds
Kansas
Why do you insist on posting in the FordCustSrvc section?
Also, yes, what he said ^^^.
Bedrck47
Elizebethtown, PA
P2198
Lack Of Heated Oxygen Sensor (Bank 2 Sensor 1) Switch, Indicates Rich
P2197
Lack Of Heated Oxygen Sensor (Bank 2 Sensor 1) Switch, Indicates Lean
P2196
Lack Of Heated Oxygen Sensor (Bank 1 Sensor 1) Switch, Indicates Rich
P0308
Cylinder 8 Misfire Detected
P0307
Cylinder 7 Misfire Detected
P0306
Cylinder 6 Misfire Detected
P0300
Random Misfire Detected
When was the last time the plugs were changed
I would replace the plugs and boots first That may be the cause of you having the O2 sensors faults
Bedrck47
Elizebethtown, PA
The other day you had a post dealing with an oil problem It always helps if you give some feedback on previous problems It also helps others that may have a similar problem.
Junker
