Codes p0131 p0151 p1131 p1151 and rough idle
Discussion in 'Engine & Performance' started by ChrisS, Mar 6, 2012.
  1. ChrisS
    ChrisS New Member
    Mar 6, 2012
    Nc
    I own a 99 4.6 xlt expedition recently the CEL has come on and I am getting the above codes and has begun to idle rough going from about 700rpm to below 500rpm. Gas mileage has always been below what the "average" is suppose to be but lately seems to be getting worse. Any suggestions on how to fix these problems other than replacing o2 sensors and do I has to replace all 4.
  2. walnuts4x4
    walnuts4x4 Supporting Member Supporting Member
    34
    6,471
    Jun 18, 2009
    Watertown, NY
    I would start by looking for a vacuum leak..... they can cause havoc on these motors and cause every code to come up.....
  3. Canadian Expy
    Canadian Expy Full Access Members
    3,039
    139
    Jul 16, 2010
    Toronto ON
    I thought it meant lighting motor swap, when you get that many codes ....:drool:
  4. ChrisS
    ChrisS New Member
    Mar 6, 2012
    Nc
    I'll check for the vacuum leak but would that affect the mpg?
  5. Canadian Expy
    3,039
    139
    Jul 16, 2010
    Toronto ON
    Yes for sure
  6. CARO'S98EB
    CARO'S98EB Full Access Members
    184
    Feb 14, 2012
    florida
    those codes are for th 2 front o2 sensors. could be water contam in the connectors, vac leak ... ck for vac leaks then ck the connectors from the O2 sensors.
Share This Page
