Hey everyone,
So I just put a level kit on my 2010 XLT and I had to replace the upper control arm on the driver's side. It's been aligned and it rides fine. It's my first attempt at this and I have a feeling I did something wrong. I did notice that the arm was awfully close to the spring when finished installing it. I figured that when I set the truck down it would raise the arm on its own. However, when I hit a pot hole or the tire drops there is a clunk on that side. I'm thinking it's the arm hitting the spring.
The problem is that there is no way to tighten the control arm bolts after the coil/strut is in place (no access to the inner bolts) and there's weight on it. I can't find anything that shows me in that year or model how to properly install it or fix the current clunk sound.
Any suggestions from you veteran expy owners and experienced knuckle busters would be much appreciated.
