jruppert
I have a 2010 Navigator and seem to be having some detonation and can't quite figure out what the deal is. It all started last year in August. I live in Michigan and drove up to the UP for a trip. I had only had the vehicle for 6 months at that point and had no issues. I filled up on E85, normally regular though. Drove to the UP and used E85 while being up there. When I got back home I went back to regular. I use regular at home because of the lack of E85 pumps in the area. Anyway, I started noticing some pinging on the driver side. This would happen at high gear with load increasing. The minute it shifts out of OD, the pinging will stop. It can be quite noticeable. Fast forward into winter, didnt notice the problem. Spring comes around and the pinging is back. Last September, I changed out the plugs. They were horrible. No fix. I drove for a couple weeks experiencing it and decided to pull injectors. I have a tester that initiates a pump or pulse to the injector. Hooked up pressured air with carb cleaner and injectors appear to be fine. I am beginning to think it could be a coil issue but not 100% sure. I have an actron and no codes to date. No misfires recorded either.
Any thoughts??
Any thoughts??
