Differential Cooler
splintrcel
Milwaukee
I have two oil coolers sitting around and i dont know what to do with them. What about using one of them on the rear differential because i know the fluid can heat up quite a bit. Any thoughts???
splintrcel
splintrcel
Milwaukee
I do have a towing package by the way so i already have the tranny cooler
Alienxtx
Collage Station'ish Texas
How do you plan on pumping the oil through the cooler? The diff oil is not under pressure.
You would have to drill/tap a feed and return line into the diff and add a pump, IMO I dont think it would be worth the trouble.
tonydiv
technical advisor
Middle River, MD
Not just that, you would also need a temp activated switch, because you wouldn't want that pump to turn on while the fluid was cold, you'll burn up the pump trying to move that thick goo.
You could always add a secondary trans cooler (they can never be too cool) or a power steering cooler, or even an engine oil cooler.
splintrcel
splintrcel
Milwaukee
I have never thought of the power steering cooler. What can i expect to get out of a oil cooler.
splintrcel
splintrcel
Milwaukee
And what will i get out of a power steering cooler. I wouldnt imagine that would get that hot.
tonydiv
technical advisor
Middle River, MD
Then you've never done any real heavy off roading. Power steering fluid boiling out of the pump is pretty common.
Whack
St Louis
Our power steering pump is driven by the belt at a speed related to engine speed. So you get this:
Towing/off-roading->Higher Engine Speed->Higher Pump Speed->Higher Fluid Temp->Faster Fluid Breakdown->Lower Pump life
There are a few cars and trucks that use a PS cooler as part of the towing package. No kidding, the Honda minivan is one of them.
Besides a second benefit is with the cooler you have more PS fluid. I consider it a plus.
